Defining contact surfaces to export to Abaqus
I have a model that is composed of a large tetrameshed section with a square removed and hex meshed. I need to tie these components together in abaqus using surfaces, but when I import into abaqus it combines the two sections into one part making it difficult to select the individual surfaces.
Is there a way to get hypermesh to export these two sections as individual parts and/or is there a way to define surface sets in hypermesh that will import into abaqus?
Thank you,
-Clay
1 - 1 of
11
I believe I found the answer here. http://forum.altairhyperworks.com/index.php?/topic/71-does-hypermesh-support-abaqus-assembly/?hl=%2Bcontact+%2Bsurface+%2Bexport#entry252
