Load Steps
I am creating MSC Nastran input deck using HyperMesh. I have the model where I want to apply multiple loads in steps.
Step-1 Bolt Preload
Step-2 External Force on model holding the preload applied in Step1
Step-3 No load at all but bolt preload
If I create different loadsteps from Utility, it seems they are going under different subcases, and in such scenario the loads would not be dependent. Each subcase would be treated as different simulation, wouldn't it? So my question is how do I create sequential steps? The .dat file should look like below.
Sol 400
CEND
STRAIN(PLOT)=ALL
STRESS(PLOT)=ALL
DISPLACEMENT(PLOT)=ALL
FORCE(PLOT)=ALL
ANALYSIS = NLSTATICS
NLSTEP = 1
STEP 1
SPC = 1
LOAD = 1
STEP 2
SPC = 2
Load = 2
STEP 3
SPC = 2
BEGIN BULK
If any card is not supported, you can input it directly by panel analysis>control cards>CASE_UNSUPPORTED_CARDS
