Separating txt file into multiple files
Hello to Everyone
I am working on data extracted from Sensor in form of txt file
the txt file contains different readings separated by space
like the following picture
I want to separate the reading 1 circled in blue to a different file and saved with name 1.txt or any format
same for 2 and 3 and the more I have the more saved files to be created
in the end i want to generate or save files like the following pic
I Got a code from kayman from Rapidminer community but i could not save all files eparately
<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="UTF-8"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="9.4.001" expanded="true" height="68" name="Read CSV" width="90" x="112" y="34"> <parameter key="csv_file" value="C:\Users\yourfolder\Downloads\1.txt"/> <parameter key="column_separators" value=";"/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="true"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="1"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value=""/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="windows-1252"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> <parameter key="1" value="att2.true.integer.attribute"/> <parameter key="2" value="att3.true.polynominal.attribute"/> <parameter key="3" value="att4.true.real.attribute"/> <parameter key="4" value="att5.true.real.attribute"/> <parameter key="5" value="att6.true.real.attribute"/> <parameter key="6" value="att7.true.polynominal.attribute"/> <parameter key="7" value="att8.true.polynominal.attribute"/> <parameter key="8" value="att9.true.polynominal.attribute"/> <parameter key="9" value="att10.true.polynominal.attribute"/> <parameter key="10" value="att11.true.polynominal.attribute"/> <parameter key="11" value="att12.true.polynominal.attribute"/> <parameter key="12" value="att13.true.polynominal.attribute"/> <parameter key="13" value="att14.true.polynominal.attribute"/> <parameter key="14" value="att15.true.integer.attribute"/> <parameter key="15" value="att16.true.polynominal.attribute"/> <parameter key="16" value="att17.true.integer.attribute"/> <parameter key="17" value="att18.true.polynominal.attribute"/> <parameter key="18" value="att19.true.real.attribute"/> <parameter key="19" value="att20.true.real.attribute"/> <parameter key="20" value="att21.true.real.attribute"/> <parameter key="21" value="att22.true.polynominal.attribute"/> <parameter key="22" value="att23.true.polynominal.attribute"/> <parameter key="23" value="att24.true.polynominal.attribute"/> <parameter key="24" value="att25.true.polynominal.attribute"/> <parameter key="25" value="att26.true.polynominal.attribute"/> <parameter key="26" value="att27.true.polynominal.attribute"/> <parameter key="27" value="att28.true.polynominal.attribute"/> <parameter key="28" value="att29.true.polynominal.attribute"/> <parameter key="29" value="att30.true.integer.attribute"/> <parameter key="30" value="att31.true.polynominal.attribute"/> <parameter key="31" value="att32.true.integer.attribute"/> <parameter key="32" value="att33.true.polynominal.attribute"/> <parameter key="33" value="att34.true.real.attribute"/> <parameter key="34" value="att35.true.real.attribute"/> <parameter key="35" value="att36.true.real.attribute"/> <parameter key="36" value="att37.true.polynominal.attribute"/> <parameter key="37" value="att38.true.polynominal.attribute"/> <parameter key="38" value="att39.true.polynominal.attribute"/> <parameter key="39" value="att40.true.polynominal.attribute"/> <parameter key="40" value="att41.true.polynominal.attribute"/> <parameter key="41" value="att42.true.polynominal.attribute"/> <parameter key="42" value="att43.true.polynominal.attribute"/> <parameter key="43" value="att44.true.polynominal.attribute"/> <parameter key="44" value="att45.true.integer.attribute"/> <parameter key="45" value="att46.true.polynominal.attribute"/> <parameter key="46" value="att47.true.integer.attribute"/> <parameter key="47" value="att48.true.polynominal.attribute"/> <parameter key="48" value="att49.true.real.attribute"/> <parameter key="49" value="att50.true.real.attribute"/> <parameter key="50" value="att51.true.real.attribute"/> <parameter key="51" value="att52.true.polynominal.attribute"/> <parameter key="52" value="att53.true.polynominal.attribute"/> <parameter key="53" value="att54.true.polynominal.attribute"/> <parameter key="54" value="att55.true.polynominal.attribute"/> <parameter key="55" value="att56.true.polynominal.attribute"/> <parameter key="56" value="att57.true.polynominal.attribute"/> <parameter key="57" value="att58.true.polynominal.attribute"/> <parameter key="58" value="att59.true.polynominal.attribute"/> <parameter key="59" value="att60.true.integer.attribute"/> <parameter key="60" value="att61.true.polynominal.attribute"/> <parameter key="61" value="att62.true.integer.attribute"/> <parameter key="62" value="att63.true.polynominal.attribute"/> <parameter key="63" value="att64.true.real.attribute"/> <parameter key="64" value="att65.true.real.attribute"/> <parameter key="65" value="att66.true.real.attribute"/> <parameter key="66" value="att67.true.polynominal.attribute"/> <parameter key="67" value="att68.true.polynominal.attribute"/> <parameter key="68" value="att69.true.polynominal.attribute"/> <parameter key="69" value="att70.true.polynominal.attribute"/> <parameter key="70" value="att71.true.polynominal.attribute"/> <parameter key="71" value="att72.true.polynominal.attribute"/> <parameter key="72" value="att73.true.polynominal.attribute"/> <parameter key="73" value="att74.true.polynominal.attribute"/> <parameter key="74" value="att75.true.integer.attribute"/> <parameter key="75" value="att76.true.polynominal.attribute"/> <parameter key="76" value="att77.true.integer.attribute"/> <parameter key="77" value="att78.true.polynominal.attribute"/> <parameter key="78" value="att79.true.real.attribute"/> <parameter key="79" value="att80.true.real.attribute"/> <parameter key="80" value="att81.true.real.attribute"/> <parameter key="81" value="att82.true.polynominal.attribute"/> <parameter key="82" value="att83.true.polynominal.attribute"/> <parameter key="83" value="att84.true.polynominal.attribute"/> <parameter key="84" value="att85.true.polynominal.attribute"/> <parameter key="85" value="att86.true.polynominal.attribute"/> <parameter key="86" value="att87.true.polynominal.attribute"/> <parameter key="87" value="att88.true.polynominal.attribute"/> <parameter key="88" value="att89.true.polynominal.attribute"/> <parameter key="89" value="att90.true.integer.attribute"/> <parameter key="90" value="att91.true.polynominal.attribute"/> <parameter key="91" value="att92.true.integer.attribute"/> <parameter key="92" value="att93.true.integer.attribute"/> <parameter key="93" value="att94.true.integer.attribute"/> <parameter key="94" value="att95.true.integer.attribute"/> <parameter key="95" value="att96.true.integer.attribute"/> <parameter key="96" value="att97.true.integer.attribute"/> <parameter key="97" value="att98.true.integer.attribute"/> <parameter key="98" value="att99.true.integer.attribute"/> <parameter key="99" value="att100.true.integer.attribute"/> <parameter key="100" value="att101.true.integer.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="trim" compatibility="9.4.001" expanded="true" height="82" name="Trim" width="90" x="246" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="generate_macro" compatibility="9.4.001" expanded="true" height="82" name="Generate Macro" width="90" x="380" y="34"> <list key="function_descriptions"> <parameter key="set" value="0"/> </list> </operator> <operator activated="true" class="loop_examples" compatibility="9.4.001" expanded="true" height="103" name="Loop Examples" width="90" x="514" y="34"> <parameter key="iteration_macro" value="row"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="9.4.001" expanded="true" height="82" name="Filter Example Range" width="90" x="112" y="34"> <parameter key="first_example" value="%{row}"/> <parameter key="last_example" value="%{row}"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.4.001" expanded="true" height="68" name="Extract Macro" width="90" x="246" y="34"> <parameter key="macro" value="a1"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="branch" compatibility="9.4.001" expanded="true" height="82" name="Branch" width="90" x="380" y="34"> <parameter key="condition_type" value="expression"/> <parameter key="expression" value="equals(%{a1},"runningsensor")"/> <parameter key="io_object" value="ANOVAMatrix"/> <parameter key="return_inner_output" value="true"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="9.4.001" expanded="true" height="82" name="Generate Macro (2)" width="90" x="179" y="34"> <list key="function_descriptions"> <parameter key="set" value="parse(%{set})+1"/> </list> </operator> <connect from_port="condition" to_op="Generate Macro (2)" to_port="through 1"/> <connect from_op="Generate Macro (2)" from_port="through 1" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <connect from_port="condition" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <operator activated="true" class="generate_attributes" compatibility="9.4.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="514" y="34"> <list key="function_descriptions"> <parameter key="set" value="str(rint(parse(%{set})))"/> </list> <parameter key="keep_all" value="true"/> </operator> <connect from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.2.000" expanded="true" height="82" name="Append (Superset)" width="90" x="648" y="34"/> <operator activated="true" class="concurrency:loop_values" compatibility="9.4.001" expanded="true" height="82" name="Loop Values" width="90" x="782" y="34"> <parameter key="attribute" value="set"/> <parameter key="iteration_macro" value="cs"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="9.4.001" expanded="true" height="103" name="Filter Examples" width="90" x="112" y="34"> <parameter key="parameter_expression" value=""/> <parameter key="condition_class" value="custom_filters"/> <parameter key="invert_filter" value="false"/> <list key="filters_list"> <parameter key="filters_entry_key" value="set.equals.%{cs}"/> </list> <parameter key="filters_logic_and" value="true"/> <parameter key="filters_check_metadata" value="false"/> </operator> <connect from_port="input 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_collection" compatibility="9.4.001" expanded="true" height="68" name="Loop Collection" width="90" x="916" y="34"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_name" value="current_set"/> <parameter key="macro_start_value" value="1"/> <parameter key="unfold" value="false"/> <process expanded="true"> <operator activated="true" class="store" compatibility="9.4.001" expanded="true" height="68" name="Store" width="90" x="447" y="34"> <parameter key="repository_entry" value="set_%{current_set}"/> </operator> <connect from_port="single" to_op="Store" to_port="input"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <description align="center" color="yellow" colored="false" height="105" resized="false" width="180" x="395" y="161">do something, like saving in a subset</description> </process> <description align="center" color="transparent" colored="false" width="126">loop through all the sets</description> </operator> <connect from_op="Read CSV" from_port="output" to_op="Trim" to_port="example set input"/> <connect from_op="Trim" from_port="example set output" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_op="Append (Superset)" to_port="example set 1"/> <connect from_op="Append (Superset)" from_port="merged set" to_op="Loop Values" to_port="input 1"/> <connect from_op="Loop Values" from_port="output 1" to_op="Loop Collection" to_port="collection"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> </process>
Can i receive help to separate the file into multile ones and save them
I attached the TXT file I used
