follower force
Can someone help me to simulate a beam subjected to non-conservative follower force , I have found a video on youtube about a beam subjected to a follower force but it was not clear , he started the explanation after he had created a beam with options like (RBE2...) , here you the video on youtube
I tried many times to create that beam like the video but I was not abe. for example , when he applied the force, the beam already contains nodes and that cross on its top !
the same video i've shared before for rigids shows how to create beam elements.
you should find something in Altair University or their youtube channel.
for your model, having only the disks geometry modelled into the CAD is enough, including the points for attaching the beams.
In HM you will create first the 2D mesh, using the fixed points as reference.
I'm attaching a very basic video as well, but again, go after some training material in Altair University.
Hello Mr adriano , How did you create the four nodes on each circle !!!
My co-supervisor told me that , as long as you came across this software where you can model a follower force on our robot , then stick to it but the problem is in my univ no one has used hypermesh and none of the teachers heard about it , thus it is of a great interest . I will mention you in one of my chapters Mr adriano . thank you so much for your valuable help
Hello Mr adriano , when I emported this design from solidworks to hypermesh , it does not allow me to create RBE2 and SPC ..etc , is there ny solution! , or can we create that in hypermsh and aplply that follower force .
the mechanism conssists of a flexible beam with a number of disks attached to it , I just want to analyse how it bends !!
what do you mean by ' it does not allow me to create RBE2 and SPC'??
What have you tried? What steps did you try?
AS long as I was not able to draw this robot on hypermesh , I tried it on solidworks then emported it on hypermesh, but when I wanted to fix the robot from the bottom and apply the follower force on the top I was not able to do that !!!
I'm trying to understand what exactly have you accomplish so far?
Do you have a valid mesh already? Do you have your material data inside HM?
Do you have your properties created?
I've not seen any of this yet in your pictures. So I can't help at all, unfortunately.
I already understood what you're trying to build. But I don't understand what you got done so far in FE model.
I h
I have not done anything due to the software hypermesh itsef , the design I showed you was made on soldiworks , then I emported it in hypermesh. please find the attached file of the design in solidworks .
the material is already defined in solidworks , ( flexible beam from any flexible material ) ( disks made from carbon fiber ) thats all
You didn't understand what HM is. I'm sorry.
You will import yoir geometry and build your model insode HM from scratch, creating your mesh, adding materials, bcs, etc.
Unless in SolidWorks you can export your mesh in Mastran format, so that it could be used, saving some work. Orherwise you will need to build your FE model from the beginning.
I recokmend you to start from Inspire as it creates a very moce initial model for you amd it is easy to use. Then export the model to HM.
Take a look at this small video for a linear static model starting from scratch, using 2D and 1D elements.
You could use something similar to that. In the past topics I`ve already shown you how to create the follower force (NL case).
You have to try and improve in HM/OS.
You did not get me well but it is okay I will figure it out myself , thank you for your response
