Frequency response analyisis
Hi
I am performing a modal frequency response analysis with OptiStruct. The model I have gives the displacement as output. However, I am interested in the acceleration as output. I tried obtaining this by checking the acceleration box under load steps => load case => subcase options output, but I could not access the acceleration result when in hyperview. Am I missing something? I can calculate the acceleration from the displacements but I feel like I should be able to get the acceleration results directly from the model.
Thx
1 - 7 of
71
hi modeators,
I performend frequency response analysis for a sandwich plate but on FRF plot, resonance peaks did not appar why, what is problem ?
can you help me?
Hi Toon,
Please, can you try to request Acceleration output from Global-output-request control cards as shown below and check.
Thank you
