How to take Properties Name and Material Name of Comps of *.inp file
Dear all,
I am studying writing tcl code to speed up modeling model,
Currently, I want to check Properties Name and Material Name of all Components in model.
Input model: *.inp (Abaqus form)
Now, from Comps > find Properties ID > Material ID
Then, take Name from Properties and Material ID
Are there any faster way to get the Properties Name and Material Name directly from Comps ID?
Thank you so much.
hm_getvalue comps id=$CompId dataname=material.name
Dear Tinh,
Thank you so much for your response.
However seem we can not take the material.name from Components, I ran on my model the return result for material is NA,
if I change to material.id the return value is 0.
Currently, I can get the material.name from property.id
hm_getvalue props id=$PropsId dataname=material.name
Could you please have a check on it?
hm_getvalue comps id=$CompId dataname=property.name
