How to use batchmesher to apply washer on a 3d hole
水煮电吹风
水煮电吹风 Altair Community Member
edited August 2022 in Community Q&A
Hi,I'm working on a model that need to apply washer on 3d holes,I'm considering use batchmesher,but I can only apply washer on 2d holes after my try.Even with only selecting a surface on a soild with hole,the washer doesn't apply on the surface.Can batchmesher apply washer on a 3d hole?
Best regards
Welcome!
Answers
  • ArthurJANNOT
    ArthurJANNOT
    Altair Employee
    edited August 2022
    Hello,
    What type of mesh do you expect for your 3D parts, Hexa or Tetra?
    Regards,
    Arthur
  • 水煮电吹风
    edited August 2022
    Hello,
    Regards,
    Arthur
    Hi,it's tetra.Problem is I'm just trying to apply tri mesh on a surface which is on the soild and the washer didn't show up,but it works when I separate the surface from the soild and mesh on the surfcae which is not connected with the soild.
  • ArthurJANNOT
    ArthurJANNOT
    Altair Employee
    edited August 2022
    Hello,
    For tetra mesh, using meshcontrols is recommended : (3D Tetra Meshing - 2min18)
    Please find attached a movie where global automatic detection is made and local with manual selection.
    Does it answer your question?
    Regards,
    Arthur
Welcome!
Welcome!
