What does this error means in AutoBushFD model
-top_radius of Frustum Graphics/90001 cannot be zero
Hello I am analyzing the AutobushFD Model under simple lateral force with fixed constraint base and getting this error. Kindly help me in proceedings it's urgent for me to get over this error.
The error indicates there is a problem of some sort (maybe incorrectly defined properties for the graphics)
As a workaround, you can try deactivating that graphic (id # 90001) that's throwing the error. The removal of the graphic will not affect the physics of the solution.
