🎉Community Raffle - Win $25
Join and Win
Problem with running R code in the application
User: "jozeftomas_2020"
Updated by Jocelyn
Hi everyone
I want to use the R script contained in the RapidMiner. I can run R codes
For example, draw up super words. Do kmeans or fuzzy clustering but not run
Can anyone help?
 For example, this code
install.packages ("ppclust")
library (ppclust)
library (factoextra)
library (cluster)
library (fclust)
date (iris)
x = iris [, - 5]
x
pairs (x, col = iris [, 5])
res.fcm <- fcm (x, centers = 3)
v0 <- matrix (nrow = 3, ncol = 4,
      c (5.0, 3.4, 1.4, 0.3,
        6.7, 3.0, 5.6, 2.1,
        5.8, 2.7, 4.3, 1.4),
        byrow = TRUE)
print (v0)
res.fcm <- fcm (x, centers = v0)
v0 <- inaparc :: kmpp (x, k = 3) $ v
print (v0)
u0 <- inaparc :: imemberand (nrow (x), k = 3) $ u
res.fcm <- fcm (x, centers = 3, memberships = u0)
res.fcm <- fcm (x, centers = 3, initial = "hartiganwong", initial = "imember")
res.fcm <- fcm (x, centers = 3, dmetric = "correlation")
res.fcm <- fcm (x, centers = 3, m = 4)
as.data.frame (res.fcm $ u)
res.fcm $ v0
res.fcm $ v
summary (res.fcm)
res.fcm $ comp.time
Does not run
