Collect Twitter user data automatically with the Get Twitter User Details Operator
Hi there,
First of all, I am RapidMiner rooky – my apologies for any stupid question in advance. I have not found an answer to my question in the community, so here I go:
I would like to analyse Tweets containing keywords using the “Search Twitter” Operator and then automatically lookup the users that posted something containing the keywords. I know the “Get Twitter User Details” Operator allows me to fill in user-ids manually (one at a time) but I would like RapidMiner to take the user-id from the “Search Twitter” Operator and do it automatically. In the Youtube Tutorial “Discover Twitter Content Using RapidMiner” (https://www.youtube.com/watch?v=ia2iV5Ws3zo), posted in another query, I learnt that a Macro might be a way to do it but I have not made it yet to read the user-ids of the “Search Twitter” results with the Macro and then pass it over to the “Get Twitter User Details” Operator. I recon, I somehow need a loop to do it. I do not expect a final, clean solution but maybe you guys have a hint. The xml code should be attached for better understanding of my problem and ideas.
Thanks very much in advance!
Julian
<?xml version="1.0" encoding="UTF-8"?><process version="8.1.001">
<operator activated="true" class="social_media:search_twitter" compatibility="8.1.000" expanded="true" height="68" name="Search Twitter" width="90" x="45" y="85">
<parameter key="connection" value="Twitter_DUJ"/>
<parameter key="query" value="Energiewende"/>
<parameter key="result_type" value="recent or popular"/>
<parameter key="limit" value="100"/>
<parameter key="filter_by_geo_location" value="false"/>
<parameter key="radius_unit" value="miles"/>
</operator>
</process>
<operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="85">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="From-User-Id"/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="attribute_value"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="time"/>
<parameter key="block_type" value="attribute_block"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="value_matrix_row_start"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="true"/>
</operator>
</process>
<operator activated="true" class="set_macros" compatibility="8.1.001" expanded="true" height="124" name="Set Macros" width="90" x="313" y="85">
<list key="macros">
<parameter key="userid" value="#keyword1"/>
</list>
</operator>
</process>
<operator activated="true" class="social_media:get_twitter_user_details" compatibility="8.1.000" expanded="true" height="68" name="Get Twitter User Details" width="90" x="380" y="391">
<parameter key="query_type" value="name"/>
<parameter key="user" value="%{keyword1}"/>
</operator>
</process>
<operator activated="true" class="select_attributes" compatibility="8.1.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="514" y="391">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attribute" value="From-User"/>
<parameter key="attributes" value="Id|Language|Location|Name|Time-Zone|Tweets"/>
<parameter key="include_special_attributes" value="false"/>
</operator>
</process>
