File extension of log file
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<operator activated="true" class="write_csv" compatibility="8.0.001" expanded="true" height="82" name="Write CSV" width="90" x="45" y="289">
<parameter key="csv_file" value="problema"/>
<parameter key="column_separator" value=";"/>
<parameter key="write_attribute_names" value="true"/>
<parameter key="quote_nominal_values" value="true"/>
<parameter key="format_date_attributes" value="true"/>
<parameter key="append_to_file" value="false"/>
<parameter key="encoding" value="SYSTEM"/>
</operator>
</process>
Hi. Need help, please. Error message: "No log data table available". First, I named log file differently from the dataset (in "Create Log Data" operator) and creted a new folder for it. "Log" operator requests the path of folder. Did not work so I named log file with same name of dataset. Did not work either. What extension file should log file be?
