Altair RISE
Nominate Yourself Now!
How to map ADCRESULT input to actual pins on board.
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Submitted by BeachCat on Sun, 08/02/2015 - 22:55
I have a F28377D experimenters board, how do I setup VisSim to read specific pins on the board with the ADC ?
I have the TI pinouts see attached file for the board. But cant see how to map VisSim ADC blocks to them.
‹ 'Target Open failed' trying to download
1 - 6 of 61
    Altair Employee
    OP
    Submitted by pete on Tue, 08/04/2015 - 02:07.
    You do that via the ADC Config... screen. Note that their are 4 separate ADC units on the 28377, named A,B,C and D. So there are 4 separate sets of ADCxRESULTn regs. In the upper right corner of the ADC Config screen you choose the ADC unit.
    • The first column lists the result registers for a given unit.
    • The 2nd Src column lets you set the external ADC pin that will be sensed. (N/C mean No Connection)
    • The 3rd Trigger column selects the trigger to start an ADC conversion on that channel.
    • The 4th Sample Clks column lets you choose the clock duration of the ADC sample window. Hi impedence signals require longer sampling intervals to produce an accurate value.
    To read a result register into the diagram, select an Embedded > Delfino > Digital/Analog input. To configure it to a particular ADCxRESULTn register, right click the block and select the ADC unit and channel.
    Altair Employee
    OP
    Submitted by BeachCat on Tue, 08/04/2015 - 03:52.
    Yep, tried that here are the settings I used along with the vsm file, everything seems to be set as should be.
    Altair Employee
    OP
    Submitted by pete on Tue, 08/04/2015 - 04:06.
    You have ADCBRESULT0 set up to trigger on ePWM1 SOCA. Do you have ePWM1 set up to send SOCA on a proper event?
    If not, it's described here
    Altair Employee
    OP
    Submitted by BeachCat on Tue, 08/04/2015 - 05:04.
    Yes I checked that.
    I even found there is a signal on channel 3 & 5 of all the ADC units and my VisSim diagram plotted it ok.
    I also found that if I disconnected the DAC that was using the default ADC A 0 pin, it still would not work.
    Altair Employee
    OP
    Submitted by pete on Tue, 08/04/2015 - 05:18.
    Attach your .vsm file to your post so we can give it a try.
    Altair Employee
    OP
    Submitted by BeachCat on Tue, 08/04/2015 - 05:23.
    It's attached to my second post.
