🎉Community Raffle - Win $25
Join and Win
Naive Bayes - Execute Python vs RM : same model / different scoring results
User: "lionelderkrikor"
New Altair Community Member
Updated by Jocelyn
Hi,
I'm doing some experimentations on RM :  I compare the results of "Naive-Bayes" operator
and those obtained from "Execute Python" operator using the "Deals" dataset.
In "Execute Python", the building, applying of the model and calculation of scoring are performed using sckit-learn.
For RM,  I use the "Naive-Bayes" operator and the "Cross-Validation" operator.
After executing the process, something is weird :
 - I have in both cases, strictly the same "Distribution Table" (so I think the builded model is the same in both cases)
but
 - The confusion matrix, the mean accuracy, the weighted mean recall and the weighted mean precision are systematically differents : the confusion matrix are differents and the performances of RM (~92%) are greater than those Execute Python (~88%) on the same dataset.
Here you can find my process :
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve Deals" width="90" x="45" y="85">
<parameter key="repository_entry" value="//Samples/data/Deals"/>
</operator>
<operator activated="true" class="concurrency:cross_validation" compatibility="8.0.001" expanded="true" height="145" name="Cross Validation" width="90" x="179" y="34">
<operator activated="true" class="naive_bayes" compatibility="8.0.001" expanded="true" height="82" name="Naive Bayes" width="90" x="179" y="34"/>
<connect from_port="training set" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="8.0.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
</operator>
<operator activated="true" class="performance_classification" compatibility="8.0.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34">
<parameter key="weighted_mean_recall" value="true"/>
<parameter key="weighted_mean_precision" value="true"/>
<list key="class_weights"/>
</operator>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve Deals (2)" width="90" x="45" y="289">
</operator>
<operator activated="true" class="nominal_to_numerical" compatibility="8.0.001" expanded="true" height="103" name="Nominal to Numerical (2)" width="90" x="179" y="238">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="Future Customer"/>
<parameter key="invert_selection" value="true"/>
<parameter key="include_special_attributes" value="true"/>
<list key="comparison_groups"/>
</operator>
<operator activated="true" class="nominal_to_numerical" compatibility="8.0.001" expanded="true" height="103" name="Nominal to Numerical" width="90" x="380" y="238">
<parameter key="coding_type" value="unique integers"/>
</operator>
<operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="145" name="Build / Apply model" width="90" x="514" y="238">
<parameter key="script" value="import pandas as pd&#10;from sklearn.naive_bayes import GaussianNB&#10;from sklearn.model_selection import cross_val_score&#10;from sklearn.model_selection import train_test_split&#10;from sklearn.metrics import confusion_matrix&#10;from sklearn.metrics import accuracy_score&#10;from sklearn.metrics import recall_score&#10;&#10;&#10;# rm_main is a mandatory function, &#10;# the number of arguments has to be the number of input ports (can be none)&#10;def rm_main(data):&#10;&#10; # Build the model&#10; X = data.iloc[:,1:]&#10; y = data.iloc[:,0]&#10; NB = GaussianNB()&#10; NB.fit(X,y)&#10;&#10; #Calculate probability of each class.&#10;&#10; pr = NB.class_prior_ &#10; &#10; #Calculate mean of each feature per class&#10; th= NB.theta_&#10;&#10; #Apply the model&#10; y_pred = NB.predict(X)&#10; &#10; &#10; # Calculate the scoring&#10; conf_matrix = confusion_matrix(y,y_pred)&#10; &#10; acc_score_mean = (cross_val_score(NB, X, y,cv = 10, scoring = 'accuracy' )).mean()&#10; acc_score_std = (cross_val_score(NB, X, y,cv = 10, scoring = 'accuracy' )).std()&#10; acc_score = str(100* acc_score_mean) + &quot; +/- &quot; + str( 100* acc_score_std) &#10; &#10; reca_score_mean = (cross_val_score(NB, X, y,cv = 10, scoring = 'recall_weighted' )).mean()&#10; reca_score_std = (cross_val_score(NB, X, y,cv = 10, scoring = 'recall_weighted' )).std()&#10; reca_score = str(100* reca_score_mean) + &quot; +/- &quot; + str( 100* acc_score_std) &#10; &#10; precision_score_mean = (cross_val_score(NB, X, y,cv = 10, scoring = 'precision_weighted' )).mean()&#10; precision_score_std = (cross_val_score(NB, X, y,cv = 10, scoring = 'precision_weighted' )).std()&#10; precision_score = str(100* precision_score_mean) + &quot; +/- &quot; + str( 100* precision_score_std ) &#10; &#10; #Write the scores in dataframe&#10; accu_score = pd.DataFrame(data = [acc_score],columns = ['accuracy'])&#10; recall_weighted = pd.DataFrame(data = [reca_score],columns = ['weighted_mean_recall']) &#10; precision_weighted = pd.DataFrame(data = [precision_score],columns = ['weighted_mean_precision']) &#10; score = accu_score.join(recall_weighted)&#10; score = score.join(precision_weighted)&#10; &#10; theta = pd.DataFrame(data = th,columns = ['Gender = Male','Gender = Female','PM = Credit card','PM = cheque','PM = cash','Age'])&#10; proba = pd.DataFrame(data = pr, columns = ['probability'])&#10; &#10; &#10; confus_matrix = pd.DataFrame(data = conf_matrix,columns = ['true yes','true no']) &#9;&#10; &#10;&#10; # connect 4 output ports to see the results&#10; return score,theta, confus_matrix,proba"/>
</operator>
<connect from_op="Retrieve Deals" from_port="output" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="model" to_port="result 5"/>
<connect from_op="Cross Validation" from_port="example set" to_port="result 3"/>
<connect from_op="Cross Validation" from_port="performance 1" to_port="result 6"/>
<connect from_op="Retrieve Deals (2)" from_port="output" to_op="Nominal to Numerical (2)" to_port="example set input"/>
<connect from_op="Nominal to Numerical (2)" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/>
<connect from_op="Nominal to Numerical" from_port="example set output" to_op="Build / Apply model" to_port="input 1"/>
<connect from_op="Build / Apply model" from_port="output 1" to_port="result 1"/>
<connect from_op="Build / Apply model" from_port="output 2" to_port="result 2"/>
<connect from_op="Build / Apply model" from_port="output 3" to_port="result 4"/>
<connect from_op="Build / Apply model" from_port="output 4" to_port="result 7"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
<portSpacing port="sink_result 7" spacing="0"/>
<portSpacing port="sink_result 8" spacing="0"/>
</process>
</operator>
</process>
NB : I think there is a bug in sckit-learn, the mean accuracy and the weighted mean recall are strictly and systematically  equal. (tested on other datasets).
How can we explain these mysterious results ?
Thanks you for your explanation,
Regards,
Lionel
