🎉Community Raffle - Win $25
Join and Win
Convert Apply Model.Labelled Data to ExampleSet
User: "KellyM"
New Altair Community Member
Updated by Jocelyn
Hello,
I am trying to build a process that applies a previously saved model to new data.  I am pulling the data in from SQL using the Read Database operator, applying the model, and then I need to rename a column before writing the data back to SQL.  Everything is fine until I try to manipulate the output from the Apply Model operator. Is there a way to convert the labelled output data to an example set so I can manipulate the results before exporting to SQL? Also, I need everything to run as one process so I can't just save the output, retrieve it, manipulate it and write to SQL.  I've tried building two separate streams in one window to do this but haven't been able to change the order of operations to run the modeling portion before retrieving the model results.
Thank you for the help,
Kelly
