ERROR: Element quality check
Hi all,
I have a problem regarding the Optistruct Element quality.
Element # 6837, element type QUAD4.
ERROR - Validity limit violation: Vertex Angle = 297.45
upper limit = 180.00
i run a bead optimization and although I use the card
PARAM,CHECKEL,NO
it seems to make the element quality check and show the ERROR.
Can you help me what is wrong with my mesh. To me it seemes to be a regular mesh.
Thanks,
Uroš
Hi,
Send us your model please.
Could you check quality F10>2d > quad max angle ?
if it is failed. delete the element and re-create
