I2C example for F28335
Updated by Altair Forum User
Submitted by elgink on Fri, 06/28/2013 - 00:41
I am trying to communicate with an i2c device using eepromReadWriteF28335 as reference. However, I am not sure the external references and state transitions are necessary. I want to run a basic test: Send one byte to the slave device (requesting the value of a certain register) and read the return byte. Can you provide a simple example?
Thanks! Kevin
