Parameter Optimization, gives different results?
Can someone point me in the right direction on what I am doing wrong here? I want to get the best learning and momentum parameter values but the results are slightly suprising.
I'm using an optimize grid analyzer, but if I take the best parameter output from the grid (87%) and apply these directly to exactly the same data the result is only 25%. This difference is rather big, and around the same using new runs on the data so it's consistent.
Below is the code I used, so i assume I somehow misconnected things but I can't get a hold on it ...
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.3.000" expanded="true" height="68" name="Retrieve wordvector" width="90" x="112" y="34">
<parameter key="repository_entry" value="../SampleData/wordvector"/>
</operator>
<operator activated="true" class="optimize_parameters_grid" compatibility="7.3.000" expanded="true" height="103" name="Optimize Parameters (Grid)" width="90" x="313" y="34">
<list key="parameters">
<parameter key="Neural Net.learning_rate" value="[0.1;0.9;5;linear]"/>
<parameter key="Neural Net.momentum" value="[0.1;0.9;5;linear]"/>
</list>
<operator activated="true" class="concurrency:cross_validation" compatibility="7.3.000" expanded="true" height="145" name="Cross Validation" width="90" x="112" y="34">
<operator activated="true" class="neural_net" compatibility="7.3.000" expanded="true" height="82" name="Neural Net" width="90" x="179" y="34">
<list key="hidden_layers"/>
<parameter key="training_cycles" value="100"/>
<parameter key="learning_rate" value="0.1"/>
<parameter key="momentum" value="0.1"/>
</operator>
<connect from_port="training set" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.3.000" expanded="true" height="82" name="Apply Model" width="90" x="179" y="85">
</operator>
<operator activated="true" class="performance_classification" compatibility="7.3.000" expanded="true" height="82" name="Performance" width="90" x="313" y="85">
<list key="class_weights"/>
</operator>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="log" compatibility="7.3.000" expanded="true" height="82" name="Log" width="90" x="313" y="85">
<list key="log">
<parameter key="learning rate" value="operator.Neural Net.parameter.learning_rate"/>
<parameter key="momentum" value="operator.Neural Net.parameter.momentum"/>
<parameter key="performance" value="operator.Cross Validation.value.performance 1"/>
</list>
</operator>
<connect from_port="input 1" to_op="Cross Validation" to_port="example set"/>
<connect from_op="Cross Validation" from_port="performance 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="performance"/>
<portSpacing port="source_input 2" spacing="0"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
</operator>
<connect from_op="Retrieve wordvector" from_port="output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
</process>
</operator>
</process>
Fair enough, I fully understand it is only giving an indication and not a foolproof golden solution, I just recently discovered the grid and before I was spending a huge amount of time doing this manually, so this looked like a huge timesaver to me. The data and process is far from optimized indeed, just trying to get a better understanding of the logic behind the operator.
Therefore, If I run the process like 10 times with 2 given parmeters, and the results are always comparable with a minor difference, wouldn't it be safe to assume the same results would be shown using the grid ?
If the grid tels me 5 times out of 5 it is around 85% accurate for a given parameter set, and entering the same parameters in the process tells me 5 times out of 5 it's around 20% accurate it seems the grid is giving me falls results. Note that I am using exact the same dataset in all scenario's, so even with crappy data the results should be still the same, even if they may be giving me a false indication of succes. Or am I overlooking something ?
Can you share the word vector data?
