Hi,
I have the following columns:
a) id
b) month
c) year
d) value_1
e) value_2
with many other columns.
All the values in 'value_1' column, I want to sum up with group by id,month,year.
All the values in 'value_2' column, I want to sum up with group by id,month,year.
Example Set:
id month year value_1 value_2
1 Jan 2017 5 6
1 Jan 2017 7 8
1 Feb 2017 8 9
Expected result:
1 Jan 2017 12 14
1 Feb 2017 8 9
I tried to use 1 Aggregate operator with the following input:
- aggregation attribute (value_1) and aggregation functions (sum), then add entry
- aggregation attribute (value_2) and aggregation functions (sum),
- then select group by attribute id,month,year
The following is the result I gotten which is incorrect,
1) There is now only 3 columns - id,value_1,value_2
2) It seems to add up all values with the same id => I need id,month,year matches then sum up
