Hyperstudy couple with Acusolve
Mark Lin
Mark Lin Altair Community Member
edited October 2020 in Community Q&A
Hello all
I  interested in how to produce a optimization by HSt and acusolve
It would seem to had a tutorial. (Hst-1535)
But It is removed in my hyperworks help 2019、2020.
Is the tutorial still work? where can I find those model and pdf? or any other tutorial instead?
Thanks you everyone
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2020
    Hi,
    As you are not a University user, you might have access to the Help files in Altair Connect portal, otherwise you can request access using your customer credentials.
    You can download the tutorials for AcuSolve and you will find 3 of them, under the Optimization section.
    The pdf and files are large, so it would better for you to go and download them directly.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.96aa5dd0988b80c0cf6b975293a96e42.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.0afa50d0a46db222d23c96d3e9219b62.png
  • Mark Lin
    edited June 2020
    Hi  Adriano A. Koga, thank for your reply
    It is what I am exactly need!
    Thank you
Welcome!
Welcome!
