What is turbulence flux relating to EBC's?
User: "Peter Parrish_22382"
Altair Community Member
Updated by Peter Parrish_22382
Hi,
I am trying to prescribe an inlet turbulence intensity for flow past a square cylinder. I believe that This can be accomplished using an essential boundary condition; however, I need to know more details.
How is turbulence diffusion flux defined in AcuSolve? It would be great to get a detailed understanding of this option.
Here it's used in hwcfd,
Here is what I was able to find in the documentation for hwcfd
Thanks,
Peter Parrish
1 - 4 of 41
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    I would suggest using the option of intenstiy from the HM-CFD interface, unless you are absolutely sure about going the EBC way.
    I will try to find out exact definition of turbulence_flux.
    User: "acupro"
    Altair Employee
    Updated by acupro
    As ydigit shows, with the turbulence tab in the BCs for a Constant velocity inlet, you can define the turbulence intensity and length scale.  Those are not available when using the Profiled options for the inlet.
    OP
    Thanks for your help. I believe everyone may benefit from a better understanding of turbulence flux. I'm guessing it is the same as percent turbulence intensity as seen in the constant inlet condition menus.
    The reason I would like to use EBC is to possibly change the turbulence intensity depending on its position along a given special dimension.
    User: "acupro"
    Altair Employee
    Accepted Answer
    Updated by acupro
    It is definitely not the same as percent turbulent intensity.  The units of turbulence flux are kg/sec^2, where turbulence intensity is unitless.  (Turbulence_flux is generally type = free, meaning it falls out of the solution based on the other settings/values.)  I don't see any method to specify a profile of turbulence intensity on a single surface.  Probably the best you could do is split the inlet surface into a series of sections, on each of which you could specify a different turbulence intensity.  It will be stair-stepped instead of a smooth profile, but not constant.
