volume tetra
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi, I'm using volume mesh and when i try to export the file in stl format i get the message 'save invalid elements to user mark?' if i click yes and try to open the file in forge nxt it doesn't open.
please tell me the cause of the message.
Thank you.
Answers
  • Sanjay Nainani_20973
    Sanjay Nainani_20973 New Altair Community Member
    edited January 2018
    Hello,
    I think you need to correct the invalid elements.
    To see these elements press 'F5' and use the retrieve option when you click on 'element'. Then click on mask and the reverse this will show you the invalid elements. Please correct these elements.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.5fe5e16f3b148ff04be373abaa547794.png
    Thank you
Welcome!
Welcome!
