🎉Community Raffle - Win $25
Join and Win
[SOLVED] Cannot retreive stored Weka model: java.io.InvalidClassException
User: "al"
New Altair Community Member
Updated by Jocelyn
Hi all,
probably after java update 17 December, Retrieving Stored Weka model (Random Forest) crashes with error:
SEVERE: Process failed: Cannot retrieve repository data from entry '...'. Reason: Cannot load data from 'C:\...': java.io.InvalidClassException: weka.classifiers.trees.RandomForest; local class incompatible: stream classdesc serialVersionUID = -226....., local class serialVersionUID = 421......
Store and Retrieve is done on the same machine.  It started to crash recently, I suppose it could be due to java version update released in December (windows 7 machine).  But I have no clue how to fix this.
Or this could be connected with RM update to 6.2, I didn't try Storing/Retrieving with 6.2 before.
Anybody has an idea how to fix this?
Thanks,
Alex.
