[solved] Example application for Log-Operator
Hi!
From the help of operator "Log" I get the hint
to read an example from "Advanced Processes/Parameter and performance analysis".
But it seems to be in RM-Tutorial 4.4. Is there a newer one ?
Background: I want to collect (aggregated) fields from an example set also into the log.
Cheers, Frank
Cheers, Frank
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="568" width="587">
<operator activated="true" class="generate_data" compatibility="5.2.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="300">
<parameter key="target_function" value="random classification"/>
</operator>
<operator activated="true" class="aggregate" compatibility="5.2.008" expanded="true" height="76" name="Aggregate" width="90" x="179" y="120">
<list key="aggregation_attributes">
<parameter key="att1" value="sum"/>
</list>
<parameter key="group_by_attributes" value="label|"/>
</operator>
<operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log" width="90" x="313" y="120">
<parameter key="filename" value="/home/fras/test.log"/>
<list key="log">
<parameter key="field01" value="operator.Aggregate.parameter.attribute"/>
<parameter key="field02" value="operator.Aggregate.parameter.attributes"/>
</list>
</operator>
<connect from_op="Generate Data" from_port="output" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="result 1"/>
</process>
</operator>
</process>
