IDA installation exception
Dear all,
I run Rapidminer5 latest version on a WinXP 32bit box. I was installing the IDA extension to get the intelligent discovery assistant running. When starting the first time, the dialogs notes to install XSB and flora2 into the directory c:\XSBFLORABUNDLE. However, the process gives me an exception:
Exception: ch.uzh.ifi.ddis.ida.installer.exception.IDAInstallationException
Message: runflora file doesn't exist at the required location
Stack trace:
ch.uzh.ifi.ddis.ida.installer.impl.WindowsInstaller.readPrologSettings(WindowsInstaller.java:156)
ch.uzh.ifi.ddis.ida.installer.impl.OSInstallerImpl.testXSBFlora2(OSInstallerImpl.java:283)
ch.uzh.ifi.ddis.ida.installer.impl.OSInstallerImpl.installXSBFlora2Binary(OSInstallerImpl.java:87)
I could see that c:\XSBFLORABUNDLE was created. Apparently, write permissions are in place.
The dialog windows also notes that XSB and flora2 were "downloaded". The string run through very quickly, I may have not spotted it correctly.
How shall I proceed?
Thanks and best regards,
Christian
Stack trace:
Christian
