Error 205
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
I have two questions :
- Once my script runs, I have the error 205 which appears. I have seen that this error should be linked to a limit I should have fixed, but I had not placed any limit.
- I also try to make a function for a CLOAD which interacts with time, but I can't achieve to do it. Could you help me ?
Thank you for your help !
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited May 2016
    Could you share us out file of the run?
    Regards
    Rahul Rajan | Hyperworks Specialist
    www.altairhyperworks.com|rahul.rajan@altair.com
    Secure file dropbox : https://ftam1.altair.com/filedrop/rahul.rajan@altair.com
     Altair | Innovation Intelligence®
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Thanks, I replied to you with my adress : gael.baillif@ensta-bretagne.org
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Hello, did you received my file ?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Hello,
    Did you received my file ? I can send it once again if it didn't worked.
    Respectfully
    Gaël
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Hello,
    I allow me to reply once again to this topic to know if you had received my file.
    Respectfully,
    Gaël
  • Rahul Rajan_21763
    edited May 2016
    Very sorry for the late reply.I just checked and found your shared Hm file.My colleague George will comeback to you with his finding on your query in forum.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    Hi  Gaël ,
              Apologies for the delay caused
            Please share the model file and out file to my dropbox link, which is in my signature. Please provide the CLOAD function also
  • Rahul Rajan_21763
    edited May 2016
    George I have shared hm file to you.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2016
    This error is mainly be caused by by a bad interface behavior or bad material definitions.
    Check the material defined (/MAT/LAW51) and enter the accurate parameters. For defining multi-material, /MAT/LAW51 is used. Please input the volume fraction of each material and their properties.
    LAW51 is only compatible with a 3D analysis. You have assigned the property as PSOLID, but the elements are 2D elements in the model.
    Please rectify all these and try running the analysis.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2016
    Ah thanks ! I will check it out immediately.
    I have some issues to create a shock wave like the example 19 of advanced tutorials. I can't manage to make this tutorial, could you help me ?
    Thank you once again for your help.
    Respectfully
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2016
    Please elaborate on the issues you are facing while creating the model.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2016
    So basicely, I cannot create a fonction of time. I do not know how to create one, and I did not find any piece of information in the tutorials.
    Moreover, I tried to recreate the example 19 : shock wave, but the mesh is displaced by the shock wave.
    Basically, I just need to create a shock wave in the air and I cannot manage to do it.
    Thank you for your help,
    Respectfully
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2016
    Hello,
    I would like to know if you had a solution to my problems, or if you could just give me some pieces of information.
    Respectfully
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2016
    Hello,
    I just like to refresh this subject.
    Respectfully
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2016
    Hello  Gaël Bailli,
    Extreme apologies for a delayed response.
    Please go through these links: http://www.altairuniversity.com/wp-content/uploads/2012/08/Example_13.pdf   This is a shock-wave propagation tutorial.
    http://www.altairuniversity.com/wp-content/uploads/2015/11/Poster_Laser_shock_experiments_RADIOSS_ZAGOURI_SIMCHOC-CNRS.pdf
    http://www.altairatc.com/europe/eatc2013-abstracts/day1/session-7/ensma.html
    These are some information related to your subject. Also you can find some research papers on shock propagation using Altair HyperWorks in the web.
Welcome!
Welcome!
