🎉Community Raffle - Win $25
Join and Win
"Is the webservice available without logging in?"
User: "ivo"
New Altair Community Member
Updated by Jocelyn
Hi All!
Is there a way of accessing a correctly deployed RA webservice without logging into to RA from a script?
I mean if I login to the RA and type in the URL of the webservice into the browser everything works fine and I see the desired output of the webservice. However if I log out RA and access the webservice from the browser again, I see the login page and no output. Is this a feature? Is there a way of making public webservices?
If deploying a public webservices is impossible, is there a native method of logging in that i can code into an application or script (beside try hacking around with cURL)?
Thanks for all the replies in advance!
Ivo
