"Problem interpreting RIPPER (JRIP) classification accuracy"
Hi,
I'm new to this forum and also quite new to RapidMiner, and I have a question to which I haven't found answer from manuals or forums. I apologize if this is too trivial question for this forum, but this is quite important issue to me.
I use the ripper (w-jrip) algorithm and RapidMiner 4.6 to find classification accuracy and rulesets for a dataset, but I'm not quite sure how to interpret the output of classification accuracy / accuracy given by the j-rip ruleset.
If I look at the "Performance vector" tab which contains the confusion matrix and accuracy, I suppose the accuracy value is the mean accuracy obtained in the cross-validation process? And the sensitivity and specificity can be calculated from the confusion matrix, which shows mean values of true/false positives and negatives obtained by the validation process, is this correct? The thing that confuses me is the tab "W-JRip" which contains the ruleset that can be used to classify the subjects into groups A and B. Is this some kind of optimal ruleset that had the best classification accuracy in some iteration of the validation process? If I apply the ruleset to the dataset I always get better classification accuracy/sensitivity/specificity compared to the values in "Performance vector" -tab. The thing that worries me is that the accuracy given by the j-rip ruleset differs sometimes even 20 precentage points from the accuracy displayed in "performance" tab. Can someone explain how is this ruleset obtained by the software and which accuracy of the two (ruleset or the one in performance-tab) is more reliable / should be used? Thank you for help!
Just for information my dataset (about 100 subjects) has groups A and B and approx. 10 variables.
