Find pairs of opposite surfaces to an element.
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
I have an FE inside a CAD. for any FE element, I have to get opposite paired surfaces.
Any solution?
Pls help. @tinh @vipin
1 - 13 of 131
    User: "tinh"
    Updated by tinh
    Try find closest surf from elem center
    OP
    @tinh Passing list of all surfaceid to get closest surface makes code slow. Do you know any code without passing surface id list?
    Secondly, if its a single surface cad, then i will not get opposite surfaces, instead i get surfaces on same plane using closest surface. How to check this?
    User: "tinh"
    Updated by tinh
    yes, hm_getclosestsurface is very slow
    using hm_measureshortestdistance is faster
    after finding the closest surf, use hm_markremove to remove it from surf mark, and continue searching next closest surf
    OP
    Ple
    Clarify abt my second doubt. @tinh
    User: "tinh"
    Updated by tinh
    Secondary,...
    => to check it, you can compare normal vector of 2 surfs, in case of single surf cad, 2 normal vectors have same direction
    otherwise, they have inversed normals
    hm_triplecos may help
    OP
    @tinh Can you elaborate. Pls.
    User: "tinh"
    Updated by tinh
    Once you find the closest surf, find its normal by hm_getsurfacenormalatcoord
    OP
    @tinh i am using hm_triplecos function. what is happening is sometimes it gives +1 or -1 for opposite surfaces/parallel surfaces both. so, getting opposite surfaces in case of ribs fails in some areas. that is, it may get surface of nearby rib too in case of plastics. what to do?
    User: "tinh"
    Updated by tinh
    Unify comps with normal + (red outer)
    Then search nearest surface in normal - only, ignore surf with triplecos +1
    OP
    @tinh how to 'Unify comps with normal + (red outer)?'
    User: "tinh"
    Updated by tinh
    Enter panel normals>surfs to adjust it
    OP
    @tinh, will be helpful in plastic comps with full of ribs?
    User: "tinh"
    Updated by tinh
    Please try and if it is not helpful, tell us reason
