🎉Community Raffle - Win $25
Join and Win
selecting nodes depending on their coordinates
Hello,
I'm a new user of tcl languaje and HyperMesh macros, and I have a problem selecting nodes in a tcl script.
I want to create a list with nodes depending on their coordinates. For example, I want to create a list with nodes that fulfills these conditions:
0< x < 5 && 3 < y < 6 && z == 0
(the nodes that the coordinate x have between 0 and 5, and the coordinate y between 3 and 6 and the coordinate z = 0).
Is it necessary to obtain a matrix with the coordinates x, y and z of all the nodes? How can I do that in a simple way? Is there any specific command for that?
Thanks in advance
Looking forward to for your help
1 - 7 of 71
    Hi,
    try the following command:
    SYNTAX
    *createmark entity_type mark_id '?option?' list
    entity_type = nodes
    mark_id = 1 or 2
    '?option?' =
    'by box' x0 y0 z0 x1 y1 z1 syst location contained all tol
    Place entities on mark_id if they are inside/outside/on the boundary of the box.
    x0 – lower bound x coordinate
    y0 – lower bound y coordinate
    z0 – lower bound z coordinate
    x1 – upper bound x coordinate
    y1 – upper bound y coordinate
    z1 – upper bound z coordinate
    syst – the ID of a local coordinate system to which the coordinate bounds are relative to. If 0, the global axes are used.
    location – The location of the entities to find, relative to the shape. Valid values are inside, outside and boundary.
    contained – A flag that indicates whether the entire entity should meet the location criteria (1) or just any part of the entity (0) to be selected.
    all – A flag that indicates whether all entities (1) or only displayed entities (0) are considered for selection.
    tol – The tolerance to use. In most cases, this should be set to 0.
    This is currently supported for nodes, elements, components (FE only), loads, equations, loadcols, systems, systcols, vectors, vectorcols and contactsurfs.
    Take a look at HW11 help file (Desktop User's Guide)
    Regards,
    Mario
    Hi Mario,
    Thanks for your answer. The command you recommend looks good, but it doesn't work in my tcl. This is the part where I want to do that (below), but Hypermesh displays an error message 'Nodes have not been selected'.
    Is it possible that this commad doesn't work with nodes in the same plane? I mean, it can be because z1bb = z2bb?? I don't think so, but it can be possible. It doen't work even with a tolerance of 0.2
    Is there any other possibilities for doing this??
    Thanks in advande,
    *createmarkpanel nodes 1 'Select one node';
    set node_list_1b [hm_getmark nodes 1];
    if { ! [ Null node_list_1b ] } {
    set nodeId1b [ lindex $node_list_1b 0 ]
    set x1b [ hm_getentityvalue NODES $nodeId1b 'x' 0 ]
    set y1b [ hm_getentityvalue NODES $nodeId1b 'y' 0 ]
    set z1b [ hm_getentityvalue NODES $nodeId1b 'z' 0 ]
    *createmarkpanel nodes 2 'Select the second node';
    set node_list_2b [hm_getmark nodes 2];
    if { ! [ Null node_list_2b ] } {
    set nodeId2b [ lindex $node_list_2b 0 ]
    set x2b [ hm_getentityvalue NODES $nodeId2b 'x' 0 ]
    set y2b [ hm_getentityvalue NODES $nodeId2b 'y' 0 ]
    set z2b [ hm_getentityvalue NODES $nodeId2b 'z' 0 ]
    *clearmark nodes 1;
    *clearmark nodes 2;
    if {$x1b < $x2b} {
    set x1bb $x1b
    set x2bb $x2b
    } else {
    set x1bb $x2b
    set x2bb $x1b
    if {$y1b < $y2b} {
    set y1bb $y1b
    set y2bb $y2b
    } else {
    set y1bb $y2b
    set y2bb $y1b
    if {$z1b < $z2b} {
    set z1bb $z1b
    set z2bb $z2b
    } else {
    set z1bb $z2b
    set z2bb $z1b
    *createmark nodes 1 'by box' '$x1bb $y1bb $z1bb $x2bb $y2bb $z2bb 0 inside 0 1 0'
    Hi mgoiogana,
    sometimes there are still small bugs... ;-)
    try:
    *createmark nodes 1 'by box' $x1bb $y1bb $z1bb $x2bb $y2bb $z2bb 0 inside 0 1 0
    without the second ''
    Regards
    Mario
    Hi Mario,
    That was not the problem. I've tried with the second '' and without the second '', but the result is the same, the problem remains: 'Nodes have not been selected!'
    and the same happens with:
    hm_createmark nodes 1 'by box' $x1bb $y1bb $z1bb $x2bb $y2bb $z2bb 0 inside 0 1 0
    or:
    hm_createmark nodes 1 'by box' '$x1bb $y1bb $z1bb $x2bb $y2bb $z2bb 0 inside 0 1 0'
    I don't know what the reason is. I'll try to look for any other command, because I think that this new command doesn't work very well.
    Let's see what we can do...
    Anyway, thaks with your help.
    Hi,
    i have tried it with exactly your code and it works without the quotes...
    You can't see the marked nodes of course, only the message:
    24 nodes added. Total selected 24
    My system: HW11, Patches 120, 230, 402
    Regards,
    Mario
    PS: Debug the selection (2 diagonal nodes for the Box of course), i take: tk_messageBox -message 'x1bb : $x1bb'
    I have used *createmark, not hm_createmark
    Hi all,
    I found this topic, which almost explained my problem with a macro for applying pressures on ship shells.
    However, I cannot make the part with *createmark elems working.
    The part of the script I'm using is like this:
    *createmark elements 1 'by box' $minX $minY $minZ $maxX $maxY $diff 0 inside 0 1 0
    Where $minX, $maxX etc... are formerly received minimum and maximum coordinates of the component i want to apply pressure on, and $diff is the Z coord. corresponding to the water level.
    The problem is that the 'by box' option keeps selecting all of the elements in component, while it should select only those inside the bounding box.
    It also happens when I put the bounds manually (straight numbers) or if I use the macro above (by MGOIOGANA) with nodes selecting.
    Can anyone tell me what's causing this? There is no explanation of the 'by box' option in HW11 help...
    Thanks in advance.
    Regards,
    Peter
    use eval command before *createmark and put 'by box' inside curly brackets { }
    the final code should look something like this:
    eval *createmark option mark_id {'by box'} x0 y0 z0 x1 y1 z1 syst location contained all tol
    Good luck,
