Beginning and ending of joints betwwen components
Hi all,
I am creating a new script which detects joints between several components and identifies the start node and the end node. I show an example in the image below:
I am able to detect all joints with the *findmark command, but I don't know how to identify the node which 'starts' or 'ends' the joint. The start/end nodes are those which have temp nodes in the image.
Can anyone help me to do this? Any suggestion?
Thanks in advance,
Alex
Can you try with the features(command is *features_advanced) option in tools menu?
It will provide you with plot elements along the features based on break angle. Then you can try some logics with the plot elements.
Hi
If you don't find an 'hm_' command to get these vertices:
*features_advanced (as vipin suggestion)
*createmark elems 1 'by comp name' ^feature
set NodeList [join [hm_getvalue elems mark=1 dataname=nodes]]
array set Count {}
set Vertices {}
foreach NodeId $NodeList {
if {[incr Count($NodeId)]>2} {lappend Vertices $NodeId}
puts $Vertices
Before version 13 we don't have command 'hm_getvalue', so looping through each element by tcl and get its nodes is quite long. at that time, to query such data i had to use an hm template to fasten script.
Hi Alex,
Find shared nodes using hm_getnodessharedbyothercomps in mark 1, find edges and get all edge nodes in mark 2.
Then get markintersection?!
