dataset and coding problem
Hi,
I have to cluster texts (course lectures) into different categories using hierarchical clustering.
My data input is from mysql database.
1st question, what format does my data have to be in?
I also need to connect RM with the system I work for (nonprofitable org), to trigger it to run automatically after a certain period.
But I have problem with the coding..
I have looked into the documentation, but it's really confusing..
Could you suggest me on where to and what functions in which location that does :
load the data
pick learner type
construct the output model
Thanks so much!
load the data
pick learner type
Thanks so much!
