Altair RISE
Nominate Yourself Now!
(URGENT) How to enumerate from n different training and test sets??
User: "misaghb"
New Altair Community Member
Updated by Jocelyn
Hi,
I want to train a model from several training sets and apply it to several test sets.
I have 60 train sets (train_i.dat) and 60 test sets (test_i.dat) in the same folder.
How can I design a loop structure that at the first iteration loads train_1.dat and applies the learned model to test_1.dat, but in the next iteration loads train_2.dat and applies the learned model to test_2.dat and so on??
Then by using "IteratingPerformanceAverage" operator I can calculate the final performance.
Can anybody tell what operator tree structure and what xml configuration I should use to solve this problem?
I need the solution so urgently.
Thanks.
1 - 2 of 21
    User: "steffen"
    Hello misaghb
    Assignment ? Meeting ?  ;D
    The solution to your problem are RapidMiner macros.
    <operator name="Root" class="Process" expanded="yes">
        <operator name="IteratingPerformanceAverage" class="IteratingPerformanceAverage" expanded="yes">
            <parameter key="iterations" value="60"/>
            <operator name="load_train" class="ExampleSource">
                <parameter key="attributes" value="train_%{a}.aml"/>
                <parameter key="decimal_point_character" value=""/>
            </operator>
            <operator name="example_model" class="NaiveBayes">
            </operator>
            <operator name="load_test" class="ExampleSource">
                <parameter key="attributes" value="test_%{a}.aml"/>
            </operator>
            <operator name="ModelApplier" class="ModelApplier">
                <list key="application_parameters">
                </list>
            </operator>
        </operator>
    </operator>
    hope this was "fast" enough
    Steffen
    User: "misaghb"
    OP
    Dear Steffen
    Thanks a lot for your kind fast reply.
    It looks great.  :D
    Thanks again.
    - misagh.
