Importing reports that vary
Hello All,
I have a process in which we get reports that are in Excel 97-2003 file format after 65536 rows of data the data is input on sheet two of the same file so on and so forth. Depending on the day I can have a file with 3 sheets, the next day it can have 30 sheets. Sheet 1 has a header sheets 2 through XX have the data that needs to be appended to the original sheet with no new headers. I can build a macro but wanting to see if Monarch complete might have a unique way to do this already built in. Anyone have any recommendations on possible solutions?
I would love to have this on the server but am open to any suggestions.
Vanessa Tanner
Manager Optimization Services
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
Hi Vanessa,
In the spirit of this being a forum that others may reference in the future, I echo Baba's suggestion of investigating the upstream process.
On the rare occasions when the data is not in a friendly format for Monarch, it's always worth checking! If connecting to the underlying database is not possible, maybe a change in export format to xlsx, accdb or csv is possible?
I believe we have some new features in development that *may* help with the multiple sheet issue, but I'm afraid I don't have details at present.
Regards,
Steve.
------------------------------Steve Caiels
Professional Services
Altair
Original Message:
Sent: 02-25-2020 11:44 AM
Subject: Importing reports that vary
Hello All,
Vanessa Tanner
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
Were you able to find a solution that worked for this?
Baba Majekodunmi
Solutions Consultant
Altair Engineering Inc.
Manassas VA
978-275-9325
Original Message:
Hello All,
Vanessa Tanner
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
Hello Baba,Hi @Vanessa Tanner,
Baba Majekodunmi
Manassas VA
978-275-9325
Original Message:
Subject: Importing reports that varyHello All,
I would love to have this on the server but am open to any suggestions.------------------------------
Vanessa Tanner
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
Unfortunately I am having to take this outside of Monarch Complete to do. I am utilizing a macro to combine the data and using a database to manipulate the data. Hopefully Monarch will roll out some new features soon so I can re-visit the process. I did evaluate opportunities upstream before looking at Monarch as a solution unfortunately they are unable to modify they way they are sending us the data without some substantial fee's being incurred by us. As always thank you for trying to help us solution better ways to do business.
Vanessa Tanner
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
Original Message:
Sent: 03-12-2020 10:58 AM
Hi @Vanessa Tanner,
Baba Majekodunmi
Manassas VA
978-275-9325
Original Message:
Hello All,
Vanessa Tanner
Gap Inc Store Labs
San Francisco NM
(505) 462-0455
My first question is about the actual data source itself. I suspect that the underlying data source is a database of some sort. If this is the case, it would be preferred and ideal to connect directly to the data source via Monarch Complete and Automator.
If you can't connect to the database then you'll have to work with the different excel output files. The Append helper in Monarch complete will automate the work for combining all of the data across the various sheets, but this will need to be done manually for each spreadsheet. Good news is that it will be a fast manual process, the challenge is how many of these spreadsheets do you get daily?
Does this help?
Baba Majekodunmi
Manassas VA
978-275-9325
