Model problems
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Perhaps somebody can help me with the model. I got some error messages with the Boundary Conditions from Radioss if I'm running the model but I do not know where it comes from.
Thanks a lot.
1 - 4 of 41
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Your model has also shell/membrane elements, but I can not found their property. Or you forget to delete them?
    Maybe that's not the cause of your error.
    Altair Employee
    OP
    I forgot to delete them, thanks. But I have still the same error :mellow:/emoticons/default_mellow.png' title=':mellow:' /> It looks like there something wrong with the boundary conditions.
    Altair Employee
    OP
    Some new problems.
    I'm confused wht is going wrong...
    Altair Employee
    OP
    Hi,
    A function is missing in your model file which is required for running.
    It seems from the loads the function is missing. Do you have concentrated load or any imposed loads in your model?. If so, those loads require a function wrt time and the load will be ramped accordingly on to the model.
