Explore the capabilities of meshless strain life fatigue analysis from within Altair SimSolid.
What method is used to correct the elastic stresses?
In this case, I've used the default stress correction methods for EN analysis in SimSolid which are Smith, Watson, Topper (SWT) Method for tension and Fatemi-Socie (FS) for shear.
This methods are well known and documented in detail in the SimSolid Help.
What method is used to correct the elastic stresses? In this case, I've used the default stress correction methods for EN analysis in SimSolid which are Smith, Watson, Topper (SWT) Method for tension and Fatemi-Socie (FS) for shear. This methods are well known and documented in detail in the SimSolid Help.
what about correction of elastic stresses to elasto-plastic stresses?
What method is used to correct the elastic stresses? In this case, I've used the default stress correction methods for EN analysis in SimSolid which are Smith, Watson, Topper (SWT) Method for tension and Fatemi-Socie (FS) for shear. This methods are well known and documented in detail in the SimSolid Help. what about correction of elastic stresses to elasto-plastic stresses?
In this case SimSolid leverages Neuber correction
