Altair Inspire® Challenge #2: Cycling Shoe Cleat Design
Road cyclists use plastic cleats on the bottoms of their shoes to create a constant point of contact between their feet and the pedals while riding.
These cleats are adjustable to accommodate different user’s preferences, and must also resist a combination of compression (downstroke) tension (upstroke) and twisting forces (engage/disengage).
This challenge is to come up with a design for a cleat that provides sufficient strength, and durability, while limiting the stack height (pedal thickness + cleat thickness + thickness of sole of shoes) and overall weight to please the most demanding weight concious cyclists. Assume a max normal force of 2500N during the downstroke, an uplift of 300N and a twisting forces. The model comes with a suggested design space, but can be adjusted to reduce the stack height, etc. if desired. The choice of optimization is up to you.
Tip: If you have trouble running an optimization, try running an analysis to ensure the model is behaving as expected.
Level: Easy
Product Required: Altair Inspire (including personal edition)
If you would like to solve more challenges and get regular challenge release updates, Subscribe to the Altair Community Challenge forum.
The solution can be attached in the comment section of this post. The desired output format is a set of PNG or JPG files showing the solution.
The solution to Challenge Bridge Concept Design can be found Here
