🎉Community Raffle - Win $25
Join and Win
Correlation between Test and/or CAE Time history curves (ISO-18571) using Altair Compose
User: "manoj kandukuri"
Altair Employee
Updated by manoj kandukuri
1 - 4 of 41
    User: "ZAFAR HAIDER"
    Altair Community Member
    Updated by ZAFAR HAIDER
    Hi
    It is really helpful especially the way you have explained. Thanks.
    I am trying to run your file  on compose 2022 and it giving this error.
    "Error: invalid input; option is not supported in call to function figure at line number 16 in file ISO18571_Tool.oml"
    Can you please let me know what am I doing wrong?
    Altair Employee
    OP
    Hi Zafar,
    Sorry for the delay in my response. I attached the updated "ISO18571_Tool.oml" file
    In latest versions of compose we updated support of "normalized" in figure command.
    Please try it out with the updated "ISO18571_Tool.oml" file
    thanks,
    Manoj
    Hi Zafar,
    thanks,
    Manoj
    Hi Manoj
    Thanks a lot for your response. One reason I am trying to do CORA is its plots which unlike Hypergraph gives the curves of the corridors as well as start and end points. Additionally, the plots are good unlike CORA plus, the display of curves are not good. your code really helped.
    The current code is generating new error. When clicked on parameters tab I am getting the following error.
    "cannot apply [Name] in call to function get at line number 269 in file ISO18571_Tool_New.oml" and the popup is blank.
    If I click on Plot, I get this error
    It will be great if you can let me know how to fix these errors along with the method you deployed to update the support for "normalized" .
    Thanks, Zafar
    User: "Sebastian Verstraten"
    New Altair Community Member
    Updated by Sebastian Verstraten
    Hi Manoj,
    I am experiencing some trouble when running your tool. I am currently running your script on Compose 2022.5976 Business Edition. After I press the 'Compute' button my parameters are computed but I also get the following notification: 'cannot apply [Name] in call to function get at line number 191'. A similar notification pops up when I want to Plot the results: 'cannot apply [Name] in call to function get at line number 269' together with the error 'Error: invalid input; option is not supported in call to function figure at line number 306'. Is this an issue you have encountered before and if so how did you solve it?
    Thanks in advance,
    Sebastian
