Adjust boresight of a triangular corner reflector to 90°
Hi everyone,
first of all im new to Altair Feko. For my student project i would like to simulate Radar Cross Sections of different objects. I came along another thread:
Basically he is doing the same thing i have to work on for my study.
As depicted by the author himself the reflector was not aligned properly as can be seen in his and my screenshot. He said that he changed the value to 102.5m, but i dont know what value he means.
Can somebody help me to adjust the correct value, to calculate the correct RCS?
Thanks in advance,
Eric
Hi @Eric Neumann ,
Can you please attach your model (.cfx) and explain in detail what should be improved?
Best regards,
Torben
Attached is the model of a triangular Corner Reflector. I want to know if the source is placed inside the symmetry axis of the corner reflector, so the maximum radar cross section can be calculated.
Thanks,
Eric
Hi @Eric Neumann ,
Best regards,
Torben
