PARAM W3 is not found in Nastran profile
Hi guys, I am using HM in NX Nastran profile.
I am working in Sol 109.
I would like to define PARAM W3, but the PARAM W3 is not found in PARAM control cards.
So I try to add it in dat file manually. It is not working.
Please advise.
Thank you in advance.
It is not working. There is no op2 and the error is shown in f06 file.
*** USER FATAL MESSAGE 6011 (IFPCCP)
THE NDDL DEFAULT TYPE OF PARAMETER W3 DIFFERS FROM THE TYPE DETERMINED FROM PARAM CARD DEFINITION.
USER INFORMATION: NDDL TYPE IS S.P. REAL. PARAM TYPE IS INTEGER.
^^^ USER FATAL MESSAGE 9002 (IFPS)
^^^ ERROR(S) ENCOUNTERED IN THE MAIN BULK DATA SECTION
^^^ SEE MESSAGES ABOVE. ERROR ENCOUNTERED IN MODULE IFP,
1 APRIL 20, 2018 NX NASTRAN 5/ 1/14 PAGE 25
0
0
*** USER INFORMATION MESSAGE 4425 (PRTPRN)
ONE OR MORE FATAL ERRORS HAVE OCCURRED. THERE MAY BE MORE ERROR MESSAGES IN THE PRECEDING OUTPUT
Hey Teeratat,
Do you really understand meaning of the message?
I think you have to input value for W3 as '300.0' but not '300'
I had tried to use 300.0, it worked!
Very thank for you answer.
Hi Teeratat,
just simply set unsupported_param = 1 and enter param W3,
you can also add other params
