How to determine the bond fracture in BondingV3 Contact Model
Hi,
As this is the timestep that the bond breaks, I would expect to have a non-zero force value. There is some force that gives rise to the bond breaking and the force is calculated first. I would hope that in the next timestep the bond force is zero though?
Richard
That being said, looking at the code it looks like the force should be overwritten to zero when the bond breaks, I think. Either way, what are the values at the next time step?
Update:
So it's a bit of oversight from what I can see in the code. The bond force custom property is only updated when the bond is still in tact. Once it breaks there's no update to the custom properties. They will disappear once the contact no longer exists, but I think the force value will remain as long as the contact does, judging by what I see in the code.
Hi,
Richard
