🎉Community Raffle - Win $25
Join and Win
Script for component table i made is not taking component names with space. it is throwing an error. similarly i want to make it editable.
Jouher_20929User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
@tinh @Pandurang The Script for component table, i made is not taking component names with space. it is throwing an error. similarly i want to make it editable.
::hwtk::dialog .d -title 'Abaqus Component Table'
set table [::hwtk::table [.d recess].table]
pack $table -fill both -expand true
$table columncreate cid -type int -text 'Comp ID'
$table columncreate cname -text 'Comp Name'
$table columncreate cthk -type int -text 'Thickness'
$table columncreate Mname -text 'Material Name'
*createmark comps 1 displayed
set cmp [hm_getmark comps 1]
set lnd [hm_marklength comps 1]
for {set j 1} {$j <= $lnd} {incr j} {
foreach CMP $cmp {
set lm [hm_getcollectorname comps $CMP]
set thk [hm_getthickness comps $CMP]
set Pt [hm_getvalue comps id=$CMP dataname=propertyid]
if {$Pt==0} {
set values 'cid $CMP cthk {Not Assigned} cname $lm Mname {Not Assigned}';
    $table rowinsert end row$j -values $values
incr j
} elseif {$Pt!=0} {
set MaT [hm_getvalue props id=$Pt dataname=material.name]
*createmark materials 1 'by name' $MaT
set Mnd [hm_marklength mats 1]
if {$Mnd==0} {
set values 'cid $CMP cthk $thk cname $lm Mname {Not Assigned}';
incr j
} elseif {$Mnd!=0} {
set values 'cid $CMP cthk $thk cname $lm Mname $MaT';
incr j
.d post
1 - 28 of 281
    Hi jouher,
    Try
     set values [list cid $CMP cthk {Not Assigned} cname $lm Mname {Not Assigned}];
    so as to suppress variable expansion, instead of
    Regards,
    OP
    Thanks @akitoguc. But, it is displaying component name in table by removing space. But, I want the name to be as it is.
    OP
    And please suggest me how to make it editable.
    You can remove spaces from component name by:
     set lm [string map {' ' ''} $lm]
    I think you can edit string in your hwtk::table widget by default. If you want to update the component name by editting its name in the table, you can do that by setting a callback procedure to a specific column as '-valueaccept' option:
     $w columncreate cname -text 'Comp Name' -valueaccept '::SetCompName %V %P'
    The callback procedure can be something like below:
     proc ::SetCompName { table value prev } {     # FIXME: add error handling code     *renamecollector comps $prev $value     return 1; }
    Hope  it helps.
    OP
    Thanks @akitoguc. But still when i rename , it is throwing error.
    My code is:
    $table columncreate cname -text 'Comp Name' -valueaccept '::SetCompName %V %P'
    proc ::SetCompName {table value prev } {
        return 1;
    foreach CMP $cmp {
    regsub -all {\s} $lm {} lm
    if {$Pt==0} {
    incr j
    } elseif {$Pt!=0} {
    if {$Mnd==0} {
    incr j
    incr j
    .d post
    That's because of mismatch of component names; names in the table has spaces taken away, but components actually has names with spaces. Sorry I'm not clear on what you wnat to do.
    OP
    @akitoguc I just want to rename component name
    OP
    I just gave names without space and ran the script. Even then I cannot edit.
    tinhUser: "tinh"
    Updated by tinh
    why don't you use component table in Utility tab?
    PandurangUser: "Pandurang"
    Updated by Pandurang
    @Jouher
    Please try this script ......I am able to change the name of comp through table
    variable table;
    proc SetValueCallback {row col value } {
        variable table
        set id [$table cellget $row,cid]
        *setvalue comps id=$id name=$value
        return true
    proc main {} {
            $table columncreate cname -text 'Comp Name' -validatecommand 'SetValueCallback %I %C %V'
            foreach CMP $cmp {
            if {$Pt==0} {
            incr j
            } elseif {$Pt!=0} {
            if {$Mnd==0} {
            incr j
            incr j
            .d post
    main
    OP
    @tinh Component table is not there in Abaqus profile.
    OP
    @Jouher
    variable table;
        variable table
        return true
    proc main {} {
            foreach CMP $cmp {
            if {$Pt==0} {
            incr j
            } elseif {$Pt!=0} {
            if {$Mnd==0} {
            incr j
            incr j
            .d post
    main
    @Pandurang its throwing error.
    OP
    Thanks @Pandurang I have solved the issue.
    OP
    @tinh Currently as I am using regsub, component name is displayed omitting spaces. Please see the code.  I want to display name as it is .
    That is, cuurently, if i remove reg sub, it shows error whilte taking comp names with spaces.
    tinhUser: "tinh"
    Updated by tinh
    Hi Jouher
    it's due to these lines:
    you should write:
    set values [list cid $CMP cthk $thk cname $lm Mname {Not Assigned}];
    so $lm with spaces will be preserved
    OP
    @tinh Thanks Tinh, It works smoothly. Now, in the above codes what should be modified to add maximize, minimize and refresh button?
    tinhUser: "tinh"
    Updated by tinh
    Hi Jouher
    maybe hwtk:dialog will create a transient toplevel '.d'
    try using:
    wm transient .d {}
    or create window .d by
    toplevel .d
    tinhUser: "tinh"
    Updated by tinh
    to create a button:
    ::ttk:button .d.refresh -text Refresh -command p_RefreshTable
    OP
    to create a button:
    @tinh I have tried using
    set f [.d recess]
     hwtk::button $f.b1 -text 'Refresh' -command {MV}
    pack $f.b1
    And it came. Now  I have doubt that what change or command should i add so that when i click refresh button, the table should get refreshed?
    tinhUser: "tinh"
    Updated by tinh
    maybe simply... delete your table and then recreate it!, if you don't know how to access its content :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' />
    OP
    @tinhPlease tell me how to convert my material name and property name columns to combo box from above code.
    tinhUser: "tinh"
    Updated by tinh
    Hi Jouher
    maybe set -type combo
    when creating table column
    $table columncreate Mname -text 'Material Name -type combo
    if it raises error, it will tell you which types are available
    OP
    Hi Jouher
    Thanks @tinh. Drop down came for each row value by giving : '-type combobox'
    But, how to give values in that as per my code. Currently its blank.
    tinhUser: "tinh"
    Updated by tinh
    Hi Jouher
    create that column with option
    -valuelistcommand ::p_GetMaterialList
    and define the command to return list of mats
    ex:
    proc ::p_GetMaterialList args {
         hm_entitylist mats name
    Hi,
    Can we have menu options in tk table? What i mean is can we right click on a cell and create menu buttons for it like modify, delete.
    Regards
    Saumya Mishra
    tinhUser: "tinh"
    Updated by tinh
    Sure, it can.
    Refer to TkTable page in Tcl/Tk docs
    OP
    Hi @tinh, @Pandurang, @akitoguc & all,
    How to give right click edit option to each row. I checked the commands but didnt get or understand. Can you help by seeing the above code to explain how to add rightclick option.
