Altair RISE
Nominate Yourself Now!
Refine Tetramesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
Is there a possibility to create a tetramesh from a surface mesh so that it has a smaller mesh size at the surface and larger in the inside. So the mesh size should follow a gradient from outside to inside. The shape I want to mesh is a vertebrae (so no geometrical shape).
thanks, Best
J
1 - 5 of 51
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    you can keep smaller element size for enclosed volume 2d mesh & bigger element size for tetrahedral mesh.Make sure to have enclosed volume for 3d mesh.
    Altair Employee
    OP
    Hi Rahul,
    I try be clearer:
    I have a surface mesh of a vertebra. Now I want to fill it with tetra solid elements. So far it is easy. However, I want to fill it in a way that I have small tetras at the surface (corresponding to my surface mesh) and larger elements in the center (see ). Is this possible?
    Thanks, J
    Altair Employee
    OP
    User: "tinh"
    Updated by tinh
    :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' /> I think it is default pattern . Did you slice your part and view inside ?
    in case you want to control gradient size, switch tetra parameter to 'user control' and input bigger value for 'growth rate'
    <?xml version="1.0" encoding="UTF-8"?>Capture.thumb.PNG.7a6f8810b3265e3c3b998e91d15428f4.PNG
    Altair Employee
    OP
    Wow!! This is exactly what I was searching for! Thanks a lot tinh!!
    Best J
