Non-mappable solid problem
Hi,
I'm quite new at hypermesh. I'm tryign to mesh a tiny vascular stent which radius is only 3.5mm.
When I tried to mesh by 3D mehsing, it showed'Non-mappable,along face from 0 loops, need2'.
Is this problem due to the complex geometry?
if you guys find out what my solution is i'd be appreciated,
Thanks for the helps.
1 - 2 of
21
Your geometry is not complicated. Have a look at my mesh and you understand how to do:
Thank you! Very helpful to me.
