I am unable to access the option to set site on Proman. Infact all the options on Proman are disabled? how do I fix this issue?
Go back to the 2D view and it should be fine.
I guess only the 2D view is designed to follow instantly the changes you're making, so only in the 2D view many options are enabled.
Awesome this works..thanks so much
