Data Prep remove a specific string
User: "Janet_21505"
Altair Community Member
Updated by Janet_21505
​What is the best approach to solve the removal of "No Data Available" string in a column?  For instance the column could be listing name, but instead of a blank or null there is a string "No Data Available"
Janet Grimsley
VP, Business Intelligence
The Fauquier Bank
Warrenton VA
(540) 349-0215
1 - 2 of 21
    User: "Mo Abdolrahim"
    Altair Employee
    Updated by Mo Abdolrahim
    Hi Janet,
    you can create formula field and use the IF function.  Assume the column name is Name you can use the following formula:
    IF(Name="No Data Available","",Name)
    The above will create a new field.
    Regards
    Mo
    Mahmoud Abdolrahim
    Senior Implementation & Integration Engineer
    Datawatch Corporation
    MA
    (978) 935-3840
    Original Message:
    Sent: 04-13-2020 05:17 PM
    Subject: Data Prep remove a specific string
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Steve_Caiels"
    Altair Employee
    Updated by Steve_Caiels
    Hi Janet,
    In Data Prep Studio, you can right click on the column and use the 'Replace->Using Find and Replace' option. This will act on the original column or you can select the 'create new column' option, if you prefer.
    Regards,
    Steve.
    Steve Caiels
    Professional Services
    Altair
    Original Message:
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
