Submitted by Alix on Fri, 04/23/2010 - 21:44
Hi,
I want to read an optical fork mounted on a drive shaft with VisSim, and I want to estimate speed and position of the drive shaft. Using eCAP I can have access to the time between two rising edges of the fork signal, which gives me the speed (I use VisSim F280X eCAP module, which works well). Having access to the eCAP register would allow me to directly estimate the position (angle).
Is it possible to have access to the eCAP register with VisSim, and how ? I put some details in the attached drawing, to explain what eCAP register means for me.
Thanks,
