How to use hexahedral mesh to divide land with small round slopes
how to cut it, so I can use hexahedral mesh to divide land with small round slopes, need your help
this is the model, I mesh it several times,but it's not correct.
It's not so complicated. So share your model?
Here's my test:
Splitting solid by two circles
Splitting more
Make surface mesh
Solid map to get 3D mesh.
HM model:
thanks a lot. Can I use the same method to mesh this?
I cut it like this.
But some elements have no common nodes.
Is this good mesh for you?
It can be calculate.But not so that good.
You know the cause, so try to fix that!
OK,I will fix it. I thought I had cut it in a wrong way. Thanks for your guidance and time. It's very fruitful.
