Set Boundary Conditions
Hello,
I'd like to know if it is possible to model a rectangular metallic housing via single rectangles and impose an boundary condition (vanishing electric field) on all rectangles, so I don't want this housing to be meshed, in order to save simulation time. In other words, the housing's surfaces should behave like a perfect electric (PEC) ground plane. Can this be modeled in FEKO?
You can do this if you enable the FDTD solver.
Then set the BC under the Solve/Run tab.
