🎉Community Raffle - Win $25
Join and Win
Which material model should be used in OptiStruct for EPS foam?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
Expanded Polystyrene (EPS) is usually used as a package material. A quasi-static compression test was done to test its material behavior. In order to validate the material stress-strain curve from the compression test, a simulation should be done. The velocity of the compression test was about 5mm/min, so I think a static nonlinear analysis in optistruct may be proper. However, I don't know which material model is suitable for EPS foam material which has both hyperelastic and plastic behavior. Any suggestions?
<?xml version="1.0" encoding="UTF-8"?>1467674100__20171210184546.thumb.jpg.cac52db2ea18e4fb68bafb4489c6991f.jpg
Roy
