🎉Community Raffle - Win $25
Join and Win
Display element properties
User: "Burner2k"
Altair Community Member
Updated by Burner2k
Hi,
Is there a tool to display different properties associated to an element like CBUSH? For example, I updated a bunch of CBUSH elements with new orientation (referenced to a custom system/coord) but I want to review the elements to make sure they have the right systems associated with them. I can't seem to find a way to do that in HW/HM. Property info is not important (I can make it out via color coding) but a summary display like associated oriented system/vector along with property info would be nice.
1 - 11 of 111
    User: "tinh"
    Updated by tinh
    Hi
    In panel bar2 click review and click to beam elems to see its syst
    Or switch 1d representation to detail mode
    User: "Burner2k"
    OP
    Updated by Burner2k
    Hey Tinh,
    Thanks for the reply man.
    Would it be possible for you to post screen shots illustration where I can find the above options you have suggested? I tried to look around but not able to figure out where 1D detailed mode representation.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    PFA screenshot for detailed element representation.
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi, I have the same question. I have several CBUSH elements ans several Bush properties. I'd like to see the associated properties. When I click on review, I only get this :
    So there is no property information. Can I get both element and associated property?
    Thank you
    Altair Employee
    I see it is written in the window when you click on review. So if I want to check the bush properties I have to check each element ?
    Altair Employee
    Hi Alina,
    Can you try with the property table in Utility Menu, which displays properties and their associated attributes in an interactive table.
    Select the required properties form the table, right click, select display>>only selection which will display those elements with the selected property.
    User: "tinh"
    Updated by tinh
    Or switch selection type to 'property' then use entity selector to click on cbush element:
    Altair Employee
    Thank you !
    User: "Burner2k"
    OP
    Updated by Burner2k
    Hello,
    I have included an image captured from MSC Patran where I have selected the middle bar element (highlighted in pink towards the center of the image) and right click followed by 'Show Elements Attributes'. The bottom panel will pop-up. If I click on the Property Set name (in this case Fasteners), the 2nd window 'Show Element Properties' pop-ups which gives me info such as Bush Orientation Coord etc.
    Problem in HM is that Bush Orientation for CBUSH is defined during element creation and not in property. So question is how do I retrieve such information in HM when even 1D->Update->Review command fails to provide it?
    User: "tinh"
    Updated by tinh
    Enter card edit panel and select cbush elems then click edit card to see their properties
    User: "Shivani Tiwari"
    Updated by Shivani Tiwari
    <?xml version="1.0" encoding="UTF-8"?>image.png.2562445cfe78b62266fe0f923c3c557f.png
    Thank you
    Sir I also have same query but it is regarding system orientation review
